Go Back   M42club.com - Home of the BMW E30/E36 318i/iS > FAQ / REFERENCE > How-To's
Reply
Thread Tools
Old 10-17-2009, 11:51 PM   #1
jrw21
Member
jrw21's Avatar
DIY Fuel Pump Replacement
1991 318is Fuel Pump Replacement. This DIY is based on the in tank fuel pump.
Tools Required for job:
Phillips Screwdriver
Flat Head Screwdriver
8mm Socket and driver
Dremel or die grinder
Soldering gun and wire
Nitrile or Latex gloves
Replacement fuel pump is the TRE 340. http://www.treperformance.com/FuelPu...Pumps.html#340
Step 1:
Locate your fuel pump. Remove your rear seat. Under the seat/insulation you will find a panel with four phillips screws. Remove these screws to reveal your fuel pump assembly.
Step 2:
Remove the four nuts on the VDO fuel guage sender and pull the fuel sender out.
Step 3:
Turn the fuel pump assembly then pull out. This may require some "tweaking" to pull out.
Step 4:
Remove the old fuel pump.
Step 5:
Use your dremel or die grinder and grind the lower section of the fuel pump housing to fit the fuel pump for the new TRE 340.
Step 6:
Fit the new TRE 340 fuel pump into the housing, cut the supplied fuel hose to fit the space between the pump and housing. Zip tie the pump to the housing. Do not forget to attach the filter to the pump!
Step 7:
Solder the new fuel pump wire to the existing fuel pump housing plug.
Step 8:
Reassemble the fuel pump into the tank.
jrw21 is offline   Reply With Quote
Old 10-18-2009, 09:09 AM   #2
quinn11m20
Advanced Member
quinn11m20's Avatar
Good Job. I replaced mine over 10 years ago. And it was just like that.
quinn11m20 is offline   Reply With Quote
Old 11-25-2009, 03:51 PM   #3
Wizard
Advanced Member
Wizard's Avatar
Send a message via Yahoo to Wizard
Great write up....Did this to mine a couple weeks ago...This article was a life saver..
Thanks...
Dan
__________________
Wizard is offline   Reply With Quote
Old 11-27-2009, 01:31 PM   #4
LeanE30
Member
Quinn, So did you install this exact pump when you did it?
I'm thinking i'm gonna order this pump.. unless anyone has found something even better yet?
any other input or vital info you guys want to share about this option?
LeanE30 is offline   Reply With Quote
Old 12-03-2009, 02:21 PM   #5
LeanE30
Member
tick-tock,... waiting on the USPS to bring me my pump.
Old 12-05-2009, 03:08 AM   #6
fabe
Advanced Member
I've used a fuel pump made for a Mitsubishi 1.8 Lancer... Currently running Walbro pump...
fabe is offline   Reply With Quote
Old 12-13-2009, 05:17 PM   #7
benji_e30
Member
Would this work for the early model (84-87) E30s? Since these models have a dual fuel pump set-up; one under the rear seat and one by the rear/left tire.
benji_e30 is offline   Reply With Quote
Old 12-13-2009, 06:57 PM   #8
nickmpower
Senior Member
anyone know the stock LPH?
nickmpower is offline   Reply With Quote
Old 02-06-2010, 06:26 PM   #9
LeanE30
Member
Moar pics
jrw21, your writeup inspired, originally I posted this one without comments, only pictures, but other e30 people finally convinced me to add some captions.
But cheers! I hope this provides useful to others, i know yours did to me
NOTE: Submersible fuel line should be used if you question the supplied fuel line (submersible line truely is much tougher and more difficult to cut than the line that is provided with the pump.)
Quote:
Fuel Pump DIY for $80 - Install in Pictures
Car: 1991 318i 4-door - my current "Lazarus" e30 project, M42. All later e30s with the single in-tank fuel pump would follow the same procedure. Don't cross wires or leave exposed wires within arching distances. I take no responsibility for your actions, this is mere documentation of the process that I performed on one of my own cars. I have used a Walbro HP255LPH before external and internal and have been very pleased with them, for this one however, i decided to try out the TRE340 unit, slightly less expensive than the Walbro, both are obviously superior to the OEM unit when you compare flow charts. I love the Walbros and am looking forward to seeing how well this TRE performs in comparison.
What is needed:
8mm wrench or socket
Set of screwdrivers
Wire cutters
Wire Strippers
Soldering iron/gun, Solder & basic skills
Dremel or mini grinder & basic skills
$80
Quote:
~ 2 inches of submersible fuel line - check with your local marine motorsports shop, according to a couple other members, if you have to resort to getting it from an autoparts store such as NAPA, they sell it in 1-foot lengths for ~$20 a pop.
2 hours, probably less.
The rear seat of most e30s simply "pops" up, grab and lift, install is reverse.
Using a screw driver for leverage as shown, rotate the pump assembly counter-clockwise.
Pay attention to the manner in which you must move the pump to remove from the tank, this will speed the process of re-install.
Make note of positive and negative terminal positions, do not cross your wires while soldering.
Old 02-06-2010, 06:28 PM   #10
LeanE30
Member
Part#2
Quote:
Do not use the supplied fuel line. the supplied line is not designed to be submersed in fuel and is for external applications, such as on early high-arch e30s with the external main and in-tank supply.
The following picture displays the area from the base of the pump which must be removed so that the pump may seat low enough for the pick-up sock filter to attach.
...Bet you were thinking that my grinding job looked butchered huh?
Any Questions?
Old 02-07-2010, 12:13 AM   #11
fabe
Advanced Member
I've also replaced mine with the walbro fuel pump...
Old 02-08-2010, 02:29 PM   #12
Rich86
Member
Nice write up. I ended up doing mine a couple years back on the side of the road. Wasn't too bad. I think I had replaced the whole unit though and not just the pump itself.
Rich86 is offline   Reply With Quote
Old 02-10-2010, 07:09 PM   #13
AtlBMW
Member
Wow, glad I found this. I just bought today, a '92 and there is a buzz/whine going from the gas tank area. I assume it is the pump. Thanks for the write up. What are the signs besides not functioning that is is time to change?
AtlBMW is offline   Reply With Quote
Old 02-10-2010, 07:37 PM   #14
Chalino
Advanced Member
Chalino's Avatar
I've read E30 fuel pumps hum/whine noticeably even when perfectly ok...mine does.
__________________
1991 318is
2001 IS300
Chalino is offline   Reply With Quote
Old 02-10-2010, 08:31 PM   #15
AtlBMW
Member
Oh it IS noticeable, though intermittent.
Old 02-22-2010, 03:40 PM   #16
browntown
Member
Anyone have one of these fail? Seems to be a couple posts between r3v and e30tech that say the tre's are crap. I can live with a little more noise of walbro if it's a better quality unit.
Also, does anyone have pictures of retrofitting a bosch 040 (intank version of 044) onto the intank assembly?
browntown is offline   Reply With Quote
Old 02-22-2010, 04:42 PM   #17
quinn11m20
Advanced Member
quinn11m20's Avatar
I will be doing that not too far into the future. My baby's pump, relay and CPS all apparently went bad. IDK?
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Ad Management plugin by RedTyger
